The only CAM module that take your 2.5d machining way beyond profiles, pockets and faces. Even pumps up 3D machining capability by driving along specific surfaces on prismatic and 3D parts.
Experience total tool control to attack only the areas you choose, without the need of constraint boundaries or time wasting construction geometry. Give yourself the power to use Tapered, Lollipop, or T-Slot tools for undercuts or difficult to cut geometry all in one package.
The HSS toolpath is focused on single or multiple surfaces, where the others are solid or surface body based. HSS shines in creating a flowing toolpath on a group of surfaces that make up a complex 3D radius.
