SolidCAM Simultaneous 5x machining
    Benefit from the most tested and proven 5-axis CNC milling toolpaths in the indutsry with the most advanced control over all aspects of toolpath and collision checking.
    Get instant feedback with Real time CNC Machine Simulation for checking the toolpath while it is being created - you don’t have to wait until you are finished programming to run a simulation and find an error.
Pre-programmed 5-axis strategies get you and up cutting instanly including swarf milling, Port machining, Engraving, Cavity machining, Electrode machining, Impeller and Turbine blade machining.
The machine-simulation provides complete Cutter and Tool-holder gouge checking.
