SolidCAM is the complete, ‘best-in-class’ Manufacturing Suite for efficient and profitable CNC-Programming inside SolidWorks.
SolidCAM provides seamless single-window integration and full associativity with the SolidWorks design model.
Flash is required!
You never have to leave the SolidWorks' window
With the single-window integration of SolidCAM in SolidWorks, all machining operations can be defined, calculated and verified without leaving the parametric SolidWorks assembly environment.
All 2D and 3D geometries used for machining are fully associative to the SolidWorks design model. If you do any changes to your SolidWorks model, all your CAM operations will be automatically updated. In a single CAM-part, several SolidWorks configurations can be used. Each configuration can represent an independent state or production step of a workpiece.
The integrated CAD/CAM-Solution SolidWorks+SolidCAM is available from SolidCAM at a competitive Bundle-Price.
