Know before you go: Check and validate your CNC-operations
SolidCAM features an advanced simulation module with multiple options to visualize exactly how your part will be cut with all your machining operations before you generate your G-code and run it on your CNC-machine. See fully rendered, life-like details of the cutting or quickly see how just the toolpaths look. You can even see detailed simulation of how much stock is left compared to the target model after the operation(s) is completed.
Complete Machine Simulation
SolidCAM enables you to define your complete machine tool for a true simulation experience. Once set, this advanced feature supports full collision check, which is especially helpful if you run complex 4 to 5-axis indexed or simultaneous operations.
