SolidCAM is a SOLIDWORKS Gold Partner for well over a decade
Because SolidCAM is completely integrated with SOLIDWORKS CAD software, we are actually building our CAM programming within SOLIDWORKS."
Deniz Valle
Essai Corporation
SolidCAM provides the great value of the revolutionary and amazing iMachining technology.
iMachining will make you and your CNC machines more profitable and more competitive than ever before. Patented iMachining is completely unique both in its toolpath and by the method of programming with the patented Technology Wizard.
SolidCAM runs directly inside your existing SOLIDWORKS or Autodesk Inventor CAD system, with seamless integration and full tool path associativity - design changes initiate automatic tool path updates to the CAD model.
With the single-window integration, all machining operations can be defined and verified without leaving the parametric CAD assembly environment you're already used to.
Since loading SolidCAM, integrated in SOLIDWORKS, I’ve been able to program complex parts and run them without concern. The machine seems to run smoother than before, cutters last longer and confidence levels are high. Also, I'm able to train others. The software is pretty self-explanatory and the tutorials are easy to follow."
“The tight integration with SOLIDWORKS makes my design-to-production life cycle easy and fast. The SolidCAM support team is rock solid. I do some pretty complex 4-axis production projects and SolidCAM handles them very nicely.”
