SolidCAM's Advanced Mill-Turn & Swiss-Type Solutions
Get the Most Out of Your High-End Multi-Tasking CNC Machines, including Swiss-Type
You either have a multi-spindle/multi-turret CNC machine, or you want one. SolidCAM is the perfect solution for your present or future multi-tasking machining needs, with the ultimate in programming flexibility and configurability.
  • Program Multi-Turret & Multi-Spindle operations, with full turret synchronization, then watch SolidCAM's simulation of your material being machined in multiple stages, transferring from spindle to spindle without user intervention - stock inserted at one end, complex finished parts exit the other.
  • SolidCAM provides powerful programming tools that are easy-to-learn and use, covering the full range of 4/5-Axis Simultaneous Mill Turn machines.
  • SolidCAM completely supports Swiss-Type Mill-Turn Machines including multi-channel synchronization.
Advanced Mill-Turn & Swiss-Type Videos
Schedule a Demonstration:
Google Demo US/Canada
Contact Data
Details
By submitting this form you agree that SolidCAM Ltd. and entities within its enterprise are allowed to store and use the information you supply in this application form to contact you.
