The Exclusive iMachining Technology Wizard
Put the knowledge and experience of hundreds of CAM and CNC masters in the palm of your hand, as the iMachining Wizard and Tool Path take you to an entirely new level of CNC performance!
iMachining Wizard + iMachining Tool Path = the Ultimate Solution!
Using iMachining's exclusive, patented Technology Wizard, SolidCAM is the only CAM system that takes out the guesswork by automatically fine tuning the conditions for optimal cutting values.
- The industry’s first and only TRUE Wizard uses an advanced, patented "technology algorithm" that automatically produces optimized Feeds, Speeds, Depth and Width of cuts - all specifically for YOUR CNC machines, YOUR materials and YOUR tools.
- The iMachining Technology Wizard also uses stock and tool material properties, as well as CNC machine specifications, to compute and maintain optimal cutting conditions from the first cut to the last.
- Using patented "Controlled Step Over" technology, the iMachining tool path ensures that the cutting conditions set by the Wizard are strictly maintained.
- The "iMachining Level Slider" lets the user choose from 8 levels to automatically adjust for "real-world" fixture, tool holding and CNC machine conditions. The levels make it easy to overcome common challenges with spindle-rigidity, fixture-rigidity and excessive tool deflection.
Trial Download
When compared to any other CAM system to mill a part, SolidCAM's iMachining wins any benchmark in ease-of-use, programming time, cycle time and tool life.
Try iMachining on your part and your machine by downloading our trial version.
